Message 1 of 12
12:14 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have an excel spreadsheet of boreholes. The spreadsheet has the format of ID, X, Y, Z
I have tried using the 'Connect to Data' feature in Map 3D 2012 64 bit.
The ODBC connection is created and tests correctly. After connecting to the ODBC DSN and loggin in, I am able to see the fields identified in the excel file. There is also the Class available from the named range in the excel spreadsheet.
I select my Identity Property, X, Y, and Z - but that's as far as I can go. I have no opportunity to set the coordinate system and the 'connect' button does not activate.
Using Win 7 64 bit - and I have the 64 bit ODBC driver's installed.
Any ideas?
Chris
