• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Valued Contributor
    UCS_Rotating Current View
    98 Views, 1 Replies
    07-22-2008 02:43 PM
    Is there a way to rotate your view in model space without actually rotating the objects? The file is set up in an awkward position and is a little tough to work in this orientation. I know there is a way to do this in Microstation but havent figured out how to do it in AutoCAD.
    We've been working in paperspace and did the dview/twist command in the viewport but would love to be able to work in model space at a certain orientation.
    If anyone has any thoughts, please let me know. Thank you -
    Please use plain text.
    Re: UCS_Rotating Current View
    07-24-2008 02:57 PM in reply to: tgifford
    you can use dview twist in model space too ...I use as the selection....I use it all the time without fail
