• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Distinguished Contributor
    Transparency in Map 3D
    221 Views, 3 Replies
    06-18-2012 01:23 PM
    Hi All,
    I have some shape files that data connected to my drawings and shown as a solid color polygon. I set the foreground transparency 40% in order to see the USGS map on the background. But When I print out, it print out as a solid color, not transparency.
    Could some one please show me how to work with a solid color shape files so I can see the USGS map when it prints out.
    Thank you,
    Dennis
    Please use plain text.
    *Expert Elite*
    Re: Transparency in Map 3D
    06-18-2012 02:12 PM in reply to: SeattleCADD
    I don't know what Map3D-version you have, but my frist thought is: look to the checkbox within the plot-dialog. There is one especially for transparency (starting with AutoCAD 2011 I think).
    If your Map3D-version is older (when you don't have such a checkbox in the plotdialog) you have to set the sysvar MAPPLOTTRANSPARENCY.
    HTH, - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Valued Mentor
    06-18-2012 02:49 PM in reply to: SeattleCADD
    Map 2013
    Command: MAPPLOTTRANSPARENCY
    The MAPPLOTTRANSPARENCY command is no longer in use. Please use PLOTTRANSPARENCYOVERRIDE instead.
    Member
    01-28-2013 09:12 AM in reply to: SeattleCADD
    I was having the same issue with plotting polygons with transparencies in Map 2013.  I would set up varying levels of tranparency 50-80% (land use districts map) however when I would send the job to the plotter my polygons would end up solid with no transparency or the polygons would disappear completely.  Adding to the previous post if you change your PLOTTRANSPARENCYOVERRIDE setting to 2 things should plot fine.  My Plot Transparency checkbox is selected in the plot config window.  This was a real issue for me for a while and I appreciate the posts from other users that helped me get this problem fixed.
