AutoCAD Map 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Transparen cy in Map 3D
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi All,
I have some shape files that data connected to my drawings and shown as a solid color polygon. I set the foreground transparency 40% in order to see the USGS map on the background. But When I print out, it print out as a solid color, not transparency.
Could some one please show me how to work with a solid color shape files so I can see the USGS map when it prints out.
Thank you,
Dennis
Re: Transparen cy in Map 3D
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I don't know what Map3D-version you have, but my frist thought is: look to the checkbox within the plot-dialog. There is one especially for transparency (starting with AutoCAD 2011 I think).
If your Map3D-version is older (when you don't have such a checkbox in the plotdialog) you have to set the sysvar MAPPLOTTRANSPARENCY.
HTH, - alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Map 2013
Command: MAPPLOTTRANSPARENCY
The MAPPLOTTRANSPARENCY command is no longer in use. Please use PLOTTRANSPARENCYOVERRIDE instead.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I was having the same issue with plotting polygons with transparencies in Map 2013. I would set up varying levels of tranparency 50-80% (land use districts map) however when I would send the job to the plotter my polygons would end up solid with no transparency or the polygons would disappear completely. Adding to the previous post if you change your PLOTTRANSPARENCYOVERRIDE setting to 2 things should plot fine. My Plot Transparency checkbox is selected in the plot config window. This was a real issue for me for a while and I appreciate the posts from other users that helped me get this problem fixed.
