AutoCAD Map 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Texts aren't rotated after Map Export DWG to SQLLite
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Now the value is the same, both in the DWG and the sqllite database, but when I connect to the database and use the rotation value it seems that it interprets it as degrees even though I have the correct units etc in the drawing. I'm stumped. I've attached the DWG in question, if you have time it would be great to hear if you get some other result...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
what AutoCAD-Map3D version do you use? Just ot make the tests with the same release and you will then be able to use my data.
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Autocad Map 3D 2011 product version E.208.0.0.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
sorry, most of the time I spent was to reduce the video to the max-upload-limit of 1.5MB (I love it
). I hope the quality is enough to recognize what I typed.
Try to reproduce what I did (within your drawing).
HTH, - alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
and additionally the data I created (just the text-objects, no MTEXT).
I had save all (DWG and SQLite-file) in C:\TEMP
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You've done a hell of a job, thanks for putting in so much effort!
I noticed that you where able to choose text on the map export form but I don't have those options on top. I have attached a picture of my form.
I'll use this video and/or your export if I can't get it to work myself. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
And one final thing. Have you tried connecting to the database from a new drawing, adding the texts to the map via a style? I did that with your database and got the same phenomenon - the texts aren't rotated properly... ![]()
I'm starting to think that I'm a dumbass. ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have modified the MAPEXPORT.INI file in th section of SQLite (in orange the changed part), so you get the object-types also available to chose.
[FDO_SQLITE]
File=True
Rootname=False
EntTypes=Types
FeatureClass=Single
CreateClassBy=None
SupportsAppend=False
Search through your workstation through all folder (also through hidden ones) for a file called MAPEXPORT.INI and modify that option. Restart Map3D then.
May be I don't understand you correctly ... have you modified the style also in the new drawing with the formula for rotation
TXT_ANGLE / 3.14159 * 180
If you opened my drawing (drawing and db-file placed in C:\TEMP) do you see the rotation then or not?
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I forgot the formula! Now it works perfectly. I think I exported it correctly, all I was missing was the formula in the style. I've learned alot, thanks!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You're welcome! - alfred -
Alfred NESWADBA
