• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Valued Contributor
    Accepted Solution
    Texts aren't rotated after Map Export DWG to SQLLite
    135 Views, 19 Replies
    06-12-2012 03:36 AM
    I wan't to export a DWG-file with texts to a sqllite database to be used i MapGuide. The export is successfull but I can't get the rotation of texts to work properly - all the texts are horizontally aligned and not rotated. For example, the ROTATION field of a text in the sqllite database has the value 4.8376865658545531 - in the DWG the rotation property is 192.0233g - but when using the ROTATION field as the value for Rotation in the style label it isn't being rotated. Am I doing something wrong?
    Regards
    Lars Jensen
    Please use plain text.
    *Expert Elite*
    Re: Texts aren't rotated after Map Export DWG to SQLLite
    06-12-2012 03:40 AM in reply to: larsj
    IMHO the ROTATION-value is measured in radiant (based on PI) and not degrees.
    So you can make a function like
    ROT_DEGREE = ROT_RADIANT / PI * 180
    HTH, - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Valued Contributor
    06-12-2012 03:58 AM in reply to: larsj
    So when I export from a DWG to sqllite it converts radiants to degrees and that I need to convert the value in the sqllite database? If so, do you know why it converts the value?
    *Expert Elite*
    06-12-2012 04:23 AM in reply to: larsj
    The strongly correct answer is: because Autodesk did it this way :smileywink:
    The answer (I think) is that it has to be one default or there must be any config-files parallel to the SQLite-export that gives the information of what angle-units you are using, what angle is the north-direction and so on.
    So it's done easy, no config-files and just one default.
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    06-12-2012 04:30 AM in reply to: alfred.neswadba
    Ok, but I don't really understand how 192.0233g can be converted to the value 4.8376865658545531. Any idea?
    *Expert Elite*
    06-12-2012 04:38 AM in reply to: larsj
    4 question, then I start to think about what your settings may be:
    • what is your UNITS-setting in your DWG?
    • how is your north-direction set in the DWG?
    • what is your position angle-direction? Clockwise or counterclockwise?
    • are you sure that you measured your object while WCS was active (and not any UCS/UserCoordianteSystem)
    Or use this alternative: copy the drawing erase all but this one text-object and upload this new drawing.
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    06-12-2012 04:49 AM in reply to: alfred.neswadba
    Units = Meters
    Northdirection = 100.0000g
    Angle = Grads (type) and clockwise
    I'm not sure what you mean. I haven't measured any objects but there is a coordinate system specified in the drawing. Could that have something to do with it? The drawing was sent to me, I haven't produced it myself.
    *Expert Elite*
    06-12-2012 04:56 AM in reply to: alfred.neswadba
    you are working 100° based (don't know how it's called in english, in German it's "Neugrad")
    and you have your system rotated to another 0-direction then the export does
    and you have another positive angle direction.
    Look to this sketch:
    HTH, - alfred -
    [EDIT] Sorry answers crossed, I have not seen that you already answered before [/EDIT]
    Alfred NESWADBA
    Valued Contributor
    06-12-2012 05:09 AM in reply to: alfred.neswadba
    I think I understand the problem, but I don't know how to fix it. I tried changing the northdirection to 0 and changing units (in format-> units) from Grads to Decimal Degrees but I still get the same result in the sqllite database. That makes me believe that perhaps I don't understand the problem as I thought... :smileytongue:
    *Expert Elite*
    06-12-2012 05:12 AM in reply to: larsj
    You have to:
    • change your angular untis to "RADIANT"
    • your 0-direction has to point to east
    • your angular direction has to be counter-clockwise
    ....that brings you to the same settings in AutoCAD like the exporter does (hope so, have not tried it at the moment).
    Hope now that makes it more clear!
    - alfred -
    Alfred NESWADBA
