AutoCAD Map 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Text informatio n from shp file to dwg
- Highlight
- Email to a Friend
Hi. I have a problem importing text information from shp file to dwg. Using a command “Add to Map” I can see that shape file consists of Map Feature(s) objects and under Feature Properties there is an information that I need to move to Autocad environment (IGDS_TXT_;TEXTSTRING; TEXT_ANGLE). I’ve tried “mapimport” command but in result I’ve got only acad point objects with no information in it. Thx
Re: Text informatio n from shp file to dwg
- Highlight
- Email to a Friend
During _MAPIMPORT, pay attention to this, sir.
- Highlight
- Email to a Friend
after you add the shp, display manager, select the shp; style; feature labels
- Highlight
- Email to a Friend
as mentioned above, you can label the FDO features in Display Manager or you when you import the attribute data it can be used for labelling as well (Map annotation or using DisplayManager again for annoation of drawing objects).
But there is a third option. The column names indicate that the SHP files might have been created with Map, using the export option "Text" (_mapexport > Shape > Text). But you can also import point featues eitehr as block or text. Here ist the procedure for importing as ACAD text:
1 mapimport > SHP file
2 click on <ACAD_POINT> in the "Points" column
3 a small button with three dots appears on the right
4 click on it
5 dialog box "How to process points" or something along the lines appears
6 choose second option, "create text from attribute data " and select "Textstring" column
Unfortunately it will ignore Text_angle and text_size or any other format setting. But depending on your data it might be a usefull option for importing.
Good luck,
Rob
