AutoCAD Map 3D
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Text Expression
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
195 Views, 1 Replies
07-11-2008 02:02 AM
I use Map 3D 2008. How I can create a new line of Text Expression? then I can create an annotation which is seperated two attributes by a new line. Any special syntax is for creating new line? Thanks
Treo
Treo
Re: Text Expression
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-04-2008 07:10 PM in reply to:
Cadbeyond
i have just found a solution to your problem. i myself wanted to display for example CarPark_ID and CarPark_Type on the same label on different lines. using the expression builder, i added the first line "CarPark_ID", and then i added a new entry (click new) and selected Constant button and entered "\n" (without the quotes), and then added "CarPark_Type".
now i get:
PL001-001
PERMIT
all centered neatly. i assume other functions would work as well, and i discovered this only by chance. i think Autodesk should be a little more helpful in their documentation to explain how these functions are possible. best of luck
now i get:
PL001-001
PERMIT
