AutoCAD Map 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Text Disappears when Converting SHP to DWG
- Highlight
- Email to a Friend
I bring in the shapefile with the FDO connections and place a label using the attributes from one of the fields. These attributes are set to a constant map space size. Before I export to a dwg, text in the center vanishes when I zoom to certain levels. Surrounding text still appears. I zoom in until all the text appears. (BTW These are PLSS section numbers so they are quite consistent and order in their physical placemnet). Then I export to dwg and find that text is missing in the dwg. What is odd is that I am missing section numbers for a township and range in the "middle" of the data set. It is like a square was removed, because all surrounding sections are there. This is getting quite annoynig and I know from what water cooler talk that many in the office are quickly losing patience with autocad and the faith in its abilities is quickly crumbling when it comes to gis data. everything just seems so counter productive.
Using Acad Map2010
and someday when I click to open the style editor, I hope my properties bar won't disappear. And then again someday, Autocad may actually fix some of these glitches and provide you with software that is of the value that was paid for it.
Re: Text Disappears when Converting SHP to DWG- image of missing data
- Highlight
- Email to a Friend
here is an image of the missing data
- Highlight
- Email to a Friend
Murph, Thanks for helping start my new year off right....
- Highlight
- Email to a Friend
Murph,
Thanks for helping start my new year off right. Tremendous help.
Nat
- Highlight
- Email to a Friend
You might also take a look here: http://beingcivil.typepad.com/my_weblog/2012/02/fi
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
- Highlight
- Email to a Friend
NateMoore wrote:You might also take a look here: http://beingcivil.typepad.com/my_weblog/2012/02/fi
ne-tuning-fdo-labels.html , especially as you are exporting to DWG anyway.
Nate,
You missed this "Using Acad Map2010" in the first post. ![]()
Supportting the troops daily.
- Highlight
- Email to a Friend
thanks for that catch Murph. BTW do you know why opening the shapefile style editor forces the properties tab to close? I have been emailing autocad about this for almost a year now and no one responds. I have seen it occur in 2010 thru 2012
- Highlight
- Email to a Friend
nsummitt wrote:thanks for that catch Murph. BTW do you know why opening the shapefile style editor forces the properties tab to close? I have been emailing autocad about this for almost a year now and no one responds. I have seen it occur in 2010 thru 2012
No idea on why it does that with the property palette,in fact I didn't notice it did that until you posted about it the other day. It may be a dotnet issue.
