• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    New Member
    Survey file ?
    122 Views, 3 Replies
    05-15-2012 06:04 AM
    I am a surveyor who currently uses Carlson Software to process all of my data; however, I have been given the oppurtunity to explore Autocad Map 3d as a possible replacement.  Do I need a seperate program to work along with Autocadd Map 3d to process my data or is a cogo program already contained inside of the Autocadd platfrom?
    Please use plain text.
    Re: Survey file ?
    05-15-2012 07:14 AM in reply to: razorback34
    Take a look at this.
    http://docs.autodesk.com/MAP/2013/ENU/filesMAPUSE/GUID-75F6B64A-BB29-4EBA-89E4-D70AC48E48B9.htm
    That what your looking for?
    What formats does your survey data come in? AutoCAD Map can access a boat load of different data sources.
    New Member
    Re: Survey file ?
    05-16-2012 07:13 AM in reply to: razorback34
    tjmapper....thank you SO much for this quick insight...I have limited time to jump on here and kick things around so this is a huge help in me getting started!
