• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    geokh
    Summit Professional & autodesk map 3d 2012
    114 Views, 2 Replies
    04-04-2012 04:51 AM
    iam Using the Summit Professional with the map 3d ,,,and i have a question about Osnap or the 3dsnap...
    Iam using Stealth 3d Mouse model S3-Z... .
    hala my question is i want to activate the osnap or the 3dsnaop when iam drawing through the 3d mouse i manage 2 activate the osnap throught the mouse but before i start drawing using Button manager usercad : "{ESC}{ESC}Set{RET}Osmode{RET}673{RET}" and deactivate it with {ESC}{ESC}Set{RET}Osmode{RET}0{RET}..
    is there a way to activate the osnap from command line when iam drawing so i can but it as a user cad and activate it..
    i tried to click this button when iam drawing it changes the segmnets of the autoarc ... it take the command S ..and ask for a integer number ....
    George Khoury
    IT department
    Good Shepherd for engineering and computing
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: Summit Professional & autodesk map 3d 2012
    04-04-2012 05:40 AM in reply to: geokh
    Whoa... you'd better ASAP change your keyboard, man.
    Why don't you simply toggle the Osnap mode with F3..?
    geokh
    04-04-2012 08:26 AM in reply to: antoniovinci
    i know i can do this ,,,but iam using datem keybad ,,,so the autocad workspace will not be selected,so iam trying to find a simple way to toggle the snap mode while iam using the mouse ,,,to gain time than to stop working then chose the page then F3.. and there is no shortscut for the autocad in the summit
