• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Contributor
    Style Point Rotation with Map 2013
    173 Views, 4 Replies
    06-11-2012 07:03 AM
    I'm using Map 2013 and not seeing how to choose to use an expression to rotate symbols of attached shp data (see attached png file). I see where you can put in a numeric value but that's all.  Maybe I am just not seeing something?
    The "help" says you should be able to use an expression to rotate a symbol.
    Alicia
    Please use plain text.
    Product Support
    borycep
    Re: Style Point Rotation with Map 2013
    06-12-2012 03:16 PM in reply to: amm30165
    When I try this, there is a drop-down arrow available to me for Rotation. One of the options there is to Use Expression. Your dialog looks a little different from mine. Are you on Windows XP? Or do you have some custom display theme running in Windows that prevents this drop-down arrow from appearing?
    Phil Borycens
    Support Specialist
    AEC Infrastructure
    06-12-2012 03:22 PM in reply to: amm30165
    Seeing your screenshot my opinion is the OP has set the FontSize to > 100% in his Windows-options.
    That makes a lot of dialogs looking bad (and indeed hiding controls), so set it back to 100%.
    - alfred -
    Alfred NESWADBA
    Active Contributor
    06-13-2012 05:55 AM in reply to: borycep
    I am not using a custom display.
    I have Windows XP.
    ___________________________________________
       Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.111025-1629)
               Language: English (Regional Setting: English)
    System Manufacturer: LENOVO
           System Model: 6075CTO
                   BIOS: Lenovo ThinkCentre BIOS Ver 2RKT38.0
              Processor: Intel(R) Core(TM)2 Duo CPU     E4500  @ 2.20GHz (2 CPUs)
                 Memory: 3062MB RAM
              Page File: 494MB used, 5501MB available
            Windows Dir: C:\WINDOWS
        DirectX Version: DirectX 9.0c (4.09.0000.0904)
    DX Setup Parameters: Not found
         DxDiag Version: 5.03.2600.5512 32bit Unicode
    ____________________________________________________________
    I will be switching to a new computer with Windows 7 and will go to the 64-bit with Map 2013.
    Maybe that will be an improvement, we'll see.
    I will post a note if the change resolves the issue.
    Thanks for your reply.
    Alicia
    Active Contributor
    06-13-2012 06:29 AM in reply to: alfred.neswadba
    I changed the font size and now I can see the complete pull-down choices.
    Thanks you so much!
    Chalk one up in the RESOLVED column!
    Alicia
