• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    New Member
    Snapping and Viewing of Shapefile Features in Map
    84 Views, 1 Replies
    05-09-2012 06:15 AM
    I have several shapefiles that I have brought into a new autoCad drawing all with the same coordinate system. All display fine when zoomed out to the extents but when I zoom in the features dissappear. The scaleing is set to the default 0 to infinity insode of the styleing so they should dissapear like they are or like one would think if that was set to something else.
    I also can not snap to these features while zoomed in either.
    What would be causing this?
    Please use plain text.
    Valued Contributor
    ro_fr
    Re: Snapping and Viewing of Shapefile Features in Map
    05-09-2012 07:37 AM in reply to: bnowicki
    hi,
    if only some features disappear while zooming in - could be that the SHP index (*.idx)  file is damaged.
    Just delete the idx files.
    Applies to older an current version:
    http://docs.autodesk.com/MAP/2013/ENU/files/readme-map.htm - search for "idx"
    rob
