• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Member
    Snap to SHP Feature
    89 Views, 5 Replies
    05-31-2012 04:40 AM
    I am new to 2012 MAP 3D and I am working on a utility map with water valves and hydrants. I collected my points with a Trimble unit and converted them to shape files. I am unable to snap to these points,does anyone have any suggestions as to how i can use snap to draw my water mains from point to point?
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: Snap to SHP Feature
    05-31-2012 05:15 AM in reply to: jwest
    Did you just try SHIFT-right click ?
    Distinguished Mentor
    thepworth
    05-31-2012 07:50 AM in reply to: jwest
    additionally - use "D" for snap to noDe...
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    Valued Mentor
    05-31-2012 10:57 AM in reply to: thepworth
    mapimport the shp and snap to the cad points.  but it seems as though your snap is off?
    thepworth
    05-31-2012 11:00 AM in reply to: parkr4st
    note that you don't have to mapimport to osnap to a point in a shp - just snap to the node of the point.  Either set it through the snap settings or shift-right click & use the popup menu.
    C3D 2011
    Valued Mentor
    05-31-2012 01:37 PM in reply to: thepworth
    realized.  the point is if you can snap to the cad point but not the node of the shp geometry which should be coincidal, there is a problem with snap settings that needs to be tended to.
    dave
