• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Member
    dbbykerk
    Service Pack Cannot Find AutoCad Installation
    281 Views, 5 Replies
    03-13-2012 11:50 AM
    I am trying to install a service pack. the file is...
    autocadmap3d2011lockedx86sp2
    I click to install this application service pack and this error appears...
    THe update could not be installed because the expected autodesk product could not ne located on your computer. Make sure that you are using the correct update for the product.
    I believe I have the correct file for the product but I do not know were to go from here.
    Thank you for the help.
    Please use plain text.
    Distinguished Mentor
    thepworth
    Re: Service Pack Cannot Find AutoCad Installation
    03-13-2012 01:37 PM in reply to: dbbykerk
    looks like you might have a 32-bit update and a 64-bit install???  Check if you have the .exe for autocad under Programs or Programs (x86) - x86 is 32-bit.
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    Active Member
    dbbykerk
    03-13-2012 01:39 PM in reply to: thepworth
    Thanks for the reply, though I do have a 64 bit install and I tried the 32 bit just for giggles, that did not work.
    thepworth
    03-13-2012 01:41 PM in reply to: dbbykerk
    so, did you try the 64-bit service pack - http://images.autodesk.com/adsk/files/autocadmap3d2011lockedx64sp2.exe ???
    C3D 2011
    Active Member
    dbbykerk
    03-13-2012 01:50 PM in reply to: thepworth
    That did the trick, though I didn't even need an update, ah well, thanks for the help. issue solved,
    I feel like Pinky right know. Ha
    thepworth
    03-13-2012 02:00 PM in reply to: dbbykerk
    If it ain't Baroque, don't fix it...
    C3D 2011
