AutoCAD Map 3D
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Saving Feature Styles
Options
- Highlight
- Email to a Friend
262 Views, 7 Replies
01-07-2010 12:04 PM
I brought in a SHP and have pretty fancy style with a label. How on earth do you save these? The style library does not work for SHP files! HELP!!! Map 2009.
Thanks in advance!
Thanks in advance!
*Murph
Re: Saving Feature Styles
Options
- Highlight
- Email to a Friend
01-07-2010 01:51 PM in reply to:
lholland
You have to save the connected data to a .layer file. There is no way, at
present, to save a "style" to be used for another feature layer.
Murph
http://map3d.wordpress.com/
"lholland" wrote in message news:6314375@discussion.autodesk.com...
Map 2009.
Thanks in advance!
Murph
Map 2009.
Thanks in advance!
Options
- Highlight
- Email to a Friend
01-07-2010 01:54 PM in reply to:
lholland
It seems to me that the layer file assumes you are connected to the same data. Am I correct with this?
I want to save the style to use in a similar (but different starting data) project.
Options
- Highlight
- Email to a Friend
01-07-2010 02:37 PM in reply to:
lholland
The .layer file has 2 sections. One is the layer definition (identical to MapGuide), the other is the feature source (also somewhat identical to MapGuide).
The feature source section describes the connection settings (in this case, to your SHP file). So all you have to do is just change the file/directory path to point to your new SHP file(s). This is assuming the new SHP is structurally identical to the existing SHP file.
Because if you have style rules on properties that don't exist in the new SHP file, there will be problems.
- Jackie
- Jackie
*Murph
Options
- Highlight
- Email to a Friend
01-07-2010 03:59 PM in reply to:
lholland
Other than what Jackie wrote there is no way to apply a style you set up in
one feature connection to another feature connection. The layer files are
the key to enhanced stylization and "right now" there is no UI to create and
save styles.
Murph
"lholland" wrote in message news:6314520@discussion.autodesk.com...
project.
save styles.
Murph
project.
Options
- Highlight
- Email to a Friend
01-07-2010 04:22 PM in reply to:
lholland
Thanks for the info, I'm getting warmer...which is good cuz its -11F (not counting windchill) where I am!
I'm wondering where the best way to edit the *.layer files is. Just crack'er open in notepad, then?
*Murph
Options
- Highlight
- Email to a Friend
01-07-2010 04:33 PM in reply to:
lholland
Notepad is what I use, just watch any of those xml editor they can corrupt
the file. Then keep an eye on my blog in a few days it may heat you up
faster than a magpie on a hot stick.
Murph
"lholland" wrote in message news:6314601@discussion.autodesk.com...
Murph
Options
- Highlight
- Email to a Friend
04-11-2012 01:37 PM in reply to:
*Murph
No news on saving feature styles ? I'm using map 2012, but i've not finda a way to apply the same feature style from a feature to another. Is'n there a command like matchprop ??
this il very very boring !
