• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Member
    SHP File
    239 Views, 9 Replies
    03-07-2012 06:20 AM
    When importing a shp file for street names into my map Map 3D see's it as a polygon. When I edit it to text it has 4 street names in the shape of a polygon. Is there any way to convert this shape to show only one street name?
    Please use plain text.
    Valued Contributor
    Re: SHP File
    03-08-2012 08:10 AM in reply to: jwest
    Could you post a portion of the file so I could take a look at it?
    Norm
    Active Member
    Re: SHP File
    03-09-2012 04:15 AM in reply to: jwest
    Here is the shape file i was asking about. Thanks for the help.
    Murph
    Re: SHP File
    03-09-2012 04:26 AM in reply to: jwest
    What coomand are you using to create the text? I used map annonation blocks and only get one label per polygon.
    Murph
    Supportting the troops daily.
    Active Member
    Re: SHP File
    03-09-2012 04:29 AM in reply to: jwest
    Im new to map, i just pulled it in as a shape file. Should i do something diffrent?
    Murph
    Re: SHP File
    03-09-2012 04:36 AM in reply to: jwest
    Pulled it in? HOW, what command did you use? Mapimport, drag and drop from windows explorer, dataconnect or what?  How do you know it has 4 streetnames? What are you using for creating the text lables?
    Murph
    Active Member
    Re: SHP File
    03-09-2012 05:22 AM in reply to: jwest
    Dataconnect.
    Murph
    Re: SHP File
    03-09-2012 05:33 AM in reply to: jwest
    I'm only getting one label with dataconnect. (2011 version)
    Murph
    Re: SHP File
    03-09-2012 05:45 AM in reply to: jwest
    Spoiler
    Hi JWest...
    opened your shapefile in ArcInfo and it is a polygon and there are street names under the field "TextString"
    opened Map 3D and brought the shapefile
    I connected to the shapefile...then changed the style to show just the text...in the Task pane click on Style
    then see if you can change the properties to mimic my attachments...
    hope this helps...
    GO Texans!!!
    Active Member
    Re: SHP File
    03-09-2012 08:03 AM in reply to: jwest
    Thanks NERO that worked great.....
