AutoCAD Map 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
SHP File
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When importing a shp file for street names into my map Map 3D see's it as a polygon. When I edit it to text it has 4 street names in the shape of a polygon. Is there any way to convert this shape to show only one street name?
Re: SHP File
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Could you post a portion of the file so I could take a look at it?
Norm
Re: SHP File
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Here is the shape file i was asking about. Thanks for the help.
Re: SHP File
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What coomand are you using to create the text? I used map annonation blocks and only get one label per polygon.
Supportting the troops daily.
Re: SHP File
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Im new to map, i just pulled it in as a shape file. Should i do something diffrent?
Re: SHP File
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
jwest wrote:Im new to map, i just pulled it in as a shape file. Should i do something diffrent?
Pulled it in? HOW, what command did you use? Mapimport, drag and drop from windows explorer, dataconnect or what? How do you know it has 4 streetnames? What are you using for creating the text lables?
Re: SHP File
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Dataconnect.
Re: SHP File
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm only getting one label with dataconnect. (2011 version)
Re: SHP File
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi JWest...
opened your shapefile in ArcInfo and it is a polygon and there are street names under the field "TextString"
opened Map 3D and brought the shapefile
I connected to the shapefile...then changed the style to show just the text...in the Task pane click on Style
then see if you can change the properties to mimic my attachments...
hope this helps...
Re: SHP File
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks NERO that worked great.....
