• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    New Member
    Referencing a Shapefile into an AutoCAD drawing
    194 Views, 1 Replies
    02-04-2002 10:33 PM
    I was wondering if there was a way to reference an ESRI ArcView shapefile into an AutoCAD drawing without having to import (convert) the shapefile into AutoCAD entities. I was hoping to be able to bring in a "snapshot" of the shapefile into the AutoCAD drawing. I would like to be able to do this because the conversion process between a shapefile and an AutoCAD file is time consuming. Has anyone encountered this problem before? Is this capability built into AutoCAD Map or would you need an add-on package? Any help or hints on this topic would be greatly appreciated. Thanks in advance.
    Please use plain text.
    *Walsh, David
    Re: Referencing a Shapefile into an AutoCAD drawing
    02-06-2002 01:05 AM in reply to: mvolz47
    No you definitely cannot reference a shapefile
    or other external file format.
    It isn't that time consuming to convert is it? How
    big are your files? If there are many, you could use a script for the
    conversion, and run it overnight...
    Cheers,
    David
    I
    advance.
