• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    Pawn0tehLemming
    Recently-Opened File list
    592 Views, 5 Replies
    08-18-2010 07:31 PM
    Im wondering if there is something out there that is either a custom made menu or jsut a limit hack to the amount of recently opened files that come up?
    ideally id like to be able to have as many as i want in a seperate menu so i can look at and re-adress my history further than i can remember, which coincidentally is not much more than half a day.
    any ideas?
    Please use plain text.
    AllenJessup
    Re: Recently-Opened File list
    08-19-2010 06:27 AM in reply to: Pawn0tehLemming
    Funny. That feature was built in back around R2000 of 2000i but was removed within a release or 2. What do you get if you do a File > Opened and then select History from the Outlook bar? If that works you can go up a folder and choose other folders that have other links stored. You can also edit the contents of these folders in the open dialog or in explorer.
    Not exactly what you wanted but I don't know of anything else.
    Allen
    Member
    Pawn0tehLemming
    08-19-2010 03:02 PM in reply to: AllenJessup
    thanks for your feedback. Yeah the history folder doesnt really work. Ive tried using it a couple of times to find things werent showing up when i know id edited them, in the wrong chronological order, etc etc....
    Murph
    08-19-2010 04:32 PM in reply to: Pawn0tehLemming
    When you use the BLUE M or Application menu to open files you can have up to 50 in the list. You can also pin dwg files so they stay on the list by clicking on the pushpin icon next to the file name. To set the max there use the options dialog see attached.
    Murph
    Supportting the troops daily.
    Member
    Pawn0tehLemming
    08-19-2010 06:43 PM in reply to: Murph
    this is all i got
    AllenJessup
    08-20-2010 05:18 AM in reply to: Pawn0tehLemming
    There's your problem. It;'s not available until the 2010 release.
    Allen
