• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    *Srayos Endbringer
    Raster Extension Options > Memory
    410 Views, 7 Replies
    11-23-2009 12:13 PM
    I am having a problem with the memory limit setting. I am setting my
    memory limit to be 2056 MB, but it will not keep the setting. I can
    change it and get a message stating that the change will not work until
    I restart Civil 3D (Map 3D). When I do that, it goes back to a 204 MB
    limit instead of the 2 GB I want.
    How can I get Civil (Map) to remember this setting?
    EB
    Win7 Pro 64-bit
    Civil 3D 2010 SP2
    4GB RAM
    Please use plain text.
    *Murph
    Re: Raster Extension Options > Memory
    11-23-2009 12:47 PM in reply to: *Srayos Endbringer
    Try setting it to 2048 and see it it stays.
    Murph
    http://map3d.wordpress.com/
    "Srayos Endbringer" wrote in message
    news:6293993@discussion.autodesk.com...
    EB
    Win7 Pro 64-bit
    Civil 3D 2010 SP2
    4GB RAM
    *Srayos Endbringer
    11-23-2009 01:15 PM in reply to: *Srayos Endbringer
    Doesn't work. It doesn't matter what I set it to, Civil (Map) resets it
    to a strange number. This time is 206.4275 MB. I didn't have this
    problem before, but now when I need to insert a large MrSid that is 2.5
    GB this 200 MB limit is making it impossible to do any work. In fact, it
    is taking almost 3 minutes just to open a drawing I've opened before in
    about 15 seconds.
    I'm watching the task manager memory of acad.exe and it went from ~280
    MB down to ~20 MB, then climbed up to around 90 MB. I have no idea
    what's going on as I haven't changed anything on my system. This same
    drawing used to make acad.exe take up to 1.3 GB of RAM, now it's not
    doing that. I don't get it and I've got a deadline for Wednesday before
    the holiday starts to get this map out.
    ARGH.
    EB
    Win7 Pro 64-bit
    Civil 3D 2010 SP2
    4GB RAM
    *Srayos Endbringer
    11-24-2009 08:46 AM in reply to: *Srayos Endbringer
    OK, now I can't plot anything with raster images. Civil (Map) is
    refusing to use more than 204 MB of memory for raster images and I get a
    message saying that AutoCAD is running out of memory. I'm using Windows
    7 Pro 64-bit, so it should be using up to 4 GB before I run out of memory.
    I've restarted Civil and it didn't fix it. I reset the computer and
    that didn't do it either. What the heck is going on?
    EB
    Win7 Pro 64-bit
    Civil 3D 2010 SP2
    4GB RAM
    *Murph
    11-24-2009 10:38 AM in reply to: *Srayos Endbringer
    Have you cleaned out the users temp folder and the map cache folder?
    Murph
    news:6294587@discussion.autodesk.com...
    EB
    Win7 Pro 64-bit
    Civil 3D 2010 SP2
    4GB RAM
    *Srayos Endbringer
    11-24-2009 12:32 PM in reply to: *Srayos Endbringer
    I started a SR and got a reply. The Raster Memory limit has a max
    setting of 2047 MB. You cannot try a higher number or it will reset it.
    It would have been nice if the software gave a warning about that
    instead of just letting me pick it and then resetting it every time.
    Also, I knew about RASTERTHRESHOLD and RASTERPERCENT, but I did not know
    that RASTERTHRESHOLD could go above 100. I set it to 150 and my plot
    worked.
    EB
    Win7 Pro 64-bit
    Civil 3D 2010 SP2
    4GB RAM
    *Murph
    11-24-2009 12:38 PM in reply to: *Srayos Endbringer
    2047 and here I said try 2048. Off by one just like with the lottery
    numbers. : (
    Murph
    news:6294768@discussion.autodesk.com...
    worked.
    EB
    Win7 Pro 64-bit
    Civil 3D 2010 SP2
    4GB RAM
    New Member
    Olá, estou tendo problemas de memória Zerada no meu autocad civil 2010
    10-15-2012 07:03 AM in reply to: *Srayos Endbringer
    Olá, estou tendo problemas de memória zerada no meu autocad civil 2010 , windows 07 64bits.
    no campo RAM settings  - physical RAM está 0 MB
    como faço pra resolver isso?será que é problema do autocad? ou do windows 7 64bits
