• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    New Member
    Raster 2010 will not load with AutoCAD Map 3D 2012
    150 Views, 2 Replies
    07-13-2012 04:10 AM
    I am running AutoCAD Map 3d 2010 with Raster 2010 and have been experiencing a gradual loss of Raster commands.  Currently Raster will not load with AutoCAD Map 3D 2012, and the Pull Down menu for Raster Is missing.
    What is the process for restoring Raster as it normally loads with the AutoCAD desktop icon.
    Please use plain text.
    DarrenP
    Re: Raster 2010 will not load with AutoCAD Map 3D 2012
    07-13-2012 06:29 AM in reply to: Containment
    you have to have raster design 2012
    raster is not forward compatible or backwards compatible it needs to be the same version as the autocad product
    ex: autocad 2010 needs raster design 2010
    New Member
    07-13-2012 06:39 AM in reply to: DarrenP
    DarrenP,  You are right.  I am running Map 3D 2010 & Raster 2010.
