• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    *Expert Elite*
    neilyj
    Query query..!!
    225 Views, 3 Replies
    09-11-2012 03:35 AM
    I have brought in a raster ASC file (X,Y,Z) and am only interested in the red area (ultimately I want to create 1m contours layer) but cannot find a way to query the data to only show the red area.
    Any advice??
    neilyj
    (No connection with Autodesk other than using the products in the world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Please use plain text.
    *Expert Elite*
    Re: Query query..!!
    09-11-2012 05:14 AM in reply to: neilyj
    you have Civil3D, then it's easier to import the points as Civil3D-surface, then define a border to this surface (your red polyline) and set the style to show contours. The contours are also calculated with higher quality then (imho).
    Good luck, - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    *Expert Elite*
    neilyj
    Re: Query query..!!
    09-11-2012 12:50 PM in reply to: alfred.neswadba
    I'll agree to disagree on this as in my experience the contour layer (obtained via MAP tools) is far better then the same contours derived via a C3D surface.
    Even though "..all contours are lies..", the MAP version looks a lot better
    neilyj
    Product Support
    borycep
    Re: Query query..!!
    09-13-2012 10:52 AM in reply to: neilyj
    You might be able to try:
    in a text editor, manually deleting the other points outside of the extents
    OR...
    treat it as a point cloud (treat it as points), and this should allow for filtering out what you do not want
    Phil Borycens
    Support Specialist
    AEC Infrastructure
    Autodesk, Inc.
