AutoCAD Map 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Query/Feat ure Overlay
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have all of my data in an Oracle database (Gas Enterprise Model). I need to join the pipe (Line) with the meter (point) in order to have the attributes of both for a report. A query on geometry in Oracle definitely did not work and doing an overlay analysis in Map3D strips the attribute data when I create a buffer. There is nothing to join on for the tables, A Network analysis will not work because the lines are for services and don't have their connected distribution.
If anyone has any ideas on something else to try it would be appreciated.
Re: Query/Feat ure Overlay
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
O.K. I haven't run through it completely, but it appears that if don't get properties to move forward when buffering, does an intermediate step of performing an "identity" topology overlay get you towards the goal? You'd think this would be core spatial analysis functionality, so there must be a way to make it work.
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Save parts of the oracle data (line and meters) to SDF and post them or email them to me. you can message me if you need the email addy.
Supportting the troops daily.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I was able to get an answer using an SQL statement in SQL Developer. When I finally remembered the data checker function in M3D I was able to do some minor changes on one that used the geometry for the basis of the query and it worked very well. If anyone needs the SQL statement as a guide let me know and I will post it.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please post. Thanks ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is the statement I used to find the answer for points on lines and the attribute information for both. I used SQL Developer to run the process.
select a.fid,a.diameter_nominal,a.pipe_material,b.hte_loc
from okaloosagas_2012.vw_ga_pipe a,OKALOOSAGAS_2012.vw_ga_risers b
where a.fid !=b.fid
and SDO_RELATE(a.geom,b.geom, 'mask=ANYINTERACT')='TRUE'
