• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Map 3D
    Active Contributor
    Qleader
    92 Views, 2 Replies
    07-16-2012 10:09 PM
    Hi, could someone please tell me what the setting is to create a space between the leader line and the text.
    Thanks in advance
    Please use plain text.
    Valued Contributor
    Re: Qleader
    07-17-2012 10:20 AM in reply to: Ronaldo54
    Try looking for "landing gap" in the TEXT area of the properties dialogue box if you've already created your leader/text (multileader). Or in your multi-leader style under the CONTENT tab.
    If you are in dimension style, look under the TEXT tab for "offset from dim line"
    Or try typing DIMGAP
    Hope one of these gets whatyou need.
    Civil 3D 2011
    Windows 7 Prof. x64
    HP Z400 Workstation
    Intel(R) Xenon(R) CPU
    W3550 @ 3.07GHz
    6.00 GB RAM
    Active Contributor
    Re: Qleader
    07-17-2012 04:06 PM in reply to: Maine-iac
    Thank you my friend, DIMGAP did the trick! Couldn't find a 'landing gap' in the Text area of
    Properties Dialogue box though!!
