• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Re: Project Basejump for AutoCAD Map 3D Now Available on Autodesk Labs
    07-02-2012 01:01 PM in reply to: scott.sheppard
    I definitely feel your pain [cid:image001.jpg@01CD586B.EA37E8D0] Kenneth Casperson_________ Engineering Technician 2916 W M-28 Dafter, MI, 49724 * Email: kcasperson@cloverland.com * Phone: 906.632.5145 [cid:image002.jpg@01CD586B.EA37E8D0]Cell Phone: 906.440.3461 ________________________________ CONFIDENTIALITY: This email (including any attachments) may contain confidential, proprietary and privileged information, and unauthorized disclosure or use is prohibited. If you receive this email in error, please notify the sender and delete this email from your system.
    Please use plain text.
    07-03-2012 09:49 AM in reply to: kcasperson
    For those missing Bing in the background, think about OpenStreetMap (the defacto map for Apple)
    Simply add a new WMS layer in Display Manager:
    Data > Connect to Data > Add WMS Connection
    1. Add http://wms.latlon.org/?layers=osm and version as 1.1.1
    2. Cick Connect
    3.  Click Login
    4.  Check OpenStreetMap mapnik
    5. Click Add to Map
    You will the openstreetmap.org data from latlon.org
    Nice touch.  For those of you using Autodesk Infrastructure Map Server (mapguide) you can do this, even for you BASIC WEB LAYOUTS where you don't want to use Flexible web layouts
    gordon
    antoniovinci
    07-04-2012 12:40 AM in reply to: gluckett
    Thanks for the tip, G.
    If I load the Latlon layer in a WMS opensource client, I can see all the beauty of the Bing imagery, by setting it like this.
    What about you to try the same in Map/Civil 2013, instead of the OSM streets?
    jens.kuegl
    07-05-2012 06:05 AM in reply to: gluckett
    Is latlon.org a reputable service provider? I can not access latlon.org from our intranet because
    latlon.org ist listed in our blacklist of “Trend Micro OfficeScan”.
    Jens
    gperego
    07-05-2012 06:09 AM in reply to: kcasperson
    hi Gordon,
    Great suggestion!
    I just published a post in my Blog for italian users of Map 3D
    http://www.bimacademy.it/gis/2012/07/usare-openstreetmap-con-autocad-map-3d/
    You can read it in english language using the Google button to translate in the left column of the Blog
    Many thanks and regrads
    Giovanni - GimmiGIS - Perego
    Valued Contributor
    07-05-2012 07:30 AM in reply to: scott.sheppard
    Thanks, gluckett!
    It works for me as long as I'm set to V 1.1.1, however when I zoom into a size and resample I get a black tile.... Anyone else having this problem?
    -Paul
    Paul R. Mascaro
    CAD Supervisor | Engineering Design
    ENVIRON International Corporation
    System: Dell 6600M
    OS | MS Windows 7 64-bit SP1
    CPU | Intel Core i7 @ 2.70GHz
    RAM | 8.00 GB DDR3 1600 MHz (Dual-Channel @ 798MHz)
    Graphics | NVIDIA Quadro 5010M (4 Gig)
    Active Contributor
    07-05-2012 12:51 PM in reply to: pmascaro
    Yes. I get the same problem. It looks fine when zoomed out to world level, but how do I resample as I zoom in?
    Caleb Baildon
    Surveyor
    Opus International Consultants Ltd
    Greymouth, New Zealand
    07-05-2012 01:12 PM in reply to: cbaildon001
    Just right-click in the Display Manger and click Update.
    Active Contributor
    07-05-2012 07:07 PM in reply to: gluckett
    The OSM WMS is looks like a good alternative.  Thanks for the tip!
    I can see the services, but when I try to add them to the map I get:
    WARNING: The problems below were found applying style(s) to element osm:
    Coordinate transformation failed for this feature.
    Any thoughts?
    C
    gperego
    07-06-2012 12:31 AM in reply to: kcasperson
    The best way to use OpenStreetMap data is to connect before a georeferenced map.
    Data works well if you assign a coordinate system before connecting to WMS.
    It is important also to use Proxy options,otherwise Proxy can stop connection
    Regards
    Giovanni
