• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    ravivaish
    Re: Project Basejump for AutoCAD Map 3D Now Available on Autodesk Labs
    06-04-2012 08:09 AM in reply to: scott.sheppard
    I think this is a great effort. I find it better than Google Earth integration since its very easy to add the map data without even having to open Google Earth and browsing in there. Accuracy has been an issue with both the Maps and Bing. I am also having trouble keeping the raster image behind everything else on the drawing. I tried sending back and front tools but the map defaults to front as soon as it refreshes. Has anyone else seen this? I think the following additions.modifications will increase the usability of this tool.
    1. More accurate maps
    2. Availability of other GIS data through layers (an inbuilt connection with USGS seamless server or similar!!)
    3. Ability to clip data with boundaries
    4. Ability to turn layers on and off from the ribbon tabs
    Ravi Vaish
    Please use plain text.
    Valued Mentor
    06-04-2012 10:18 AM in reply to: ravivaish
    I would like to see Basejump  in Autodesk Infrastructure Map Server too (for Basic Web Layout).
    Active Contributor
    06-06-2012 09:10 PM in reply to: scott.sheppard
    It is "unable to add data" when I select "Add to Map".
    I have already set my coordinate zone. I am working through a proxy server, but it appears that I have worked past that.
    Why won't the map show?
    Cheers
    Caleb
    Caleb Baildon
    Surveyor
    Opus International Consultants Ltd
    Greymouth, New Zealand
    hardin
    06-07-2012 12:43 PM in reply to: scott.sheppard
    It's worked great for me. I like it and would like to continue using it.
    We are mainly using it to start drawings in the approximate proper geographic location.
    I would like to be able to save it (or a portion of it) in a format that regular AutoCAD users could use.
    Right now, I get the location needed, draw over some key points (road intersections, buildings, etc) then save the file or wblock the reference lines I drew.
    The AutoCAD user then plops a Google image (or other image) into the drawing I made and aligns that image to my reference lines.
    Learn, Practice, Get Better
    http://autocad-lkh.blogspot.com
    Valued Contributor
    06-07-2012 01:25 PM in reply to: hardin
    +1 I haven't released it to my department since it's going to end operation on June 30th and when it does.... Poof.... There goes the imagery w/ it. (I'm assuming we will lose connection to the server when this ends....) As hardin mentioned, it would be nice to have a way to select the area you want, clip and save the image with a world file so you do not have to rely on having the link to the host server.
    Paul R. Mascaro
    CAD Supervisor | Engineering Design
    ENVIRON International Corporation
    System: Dell 6600M
    OS | MS Windows 7 64-bit SP1
    CPU | Intel Core i7 @ 2.70GHz
    RAM | 8.00 GB DDR3 1600 MHz (Dual-Channel @ 798MHz)
    Graphics | NVIDIA Quadro 5010M (4 Gig)
    yooper_75
    06-08-2012 04:11 AM in reply to: scott.sheppard
    This has saved us a ton of time and effort. Especially useful when orienting someone to our data quickly. Please keep this in Map - we definately need this tool!
    M3D 2012 and 2013
    Win 7 Pro x64
    HP 8200 i7 - 16GB RAM
    AMD Radeon HD 6350
    Valued Contributor
    06-08-2012 08:28 AM in reply to: ravivaish
    Scott,
    Any news on an extension? It Would be nice if we could at least keep this labs feature going until the alternative to the "Google Insert" (that was pulled out from under us w/ out warning) is fully implemented into IDSS & IDSP (Civil 3D / Map 3D).
    I understand Autodesk is looking into options for us.... probably ones that are much better then Google.... but we still need something to hold over our daily workflow until a final discussion is made and implemented into the software...
    An extension on this would be much appreciated!! :smileyhappy:
    Paul
    Paul R. Mascaro
    System: Dell 6600M
    Board Manager
    06-13-2012 05:37 AM in reply to: pmascaro
    I have not heard about what comes next. I know our original agreement with Microsoft was for a limited trial, so it's not just up to us. We have to work with our partner on this one.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    06-13-2012 01:02 PM in reply to: scott.sheppard
    This works great!  I would second or third the motion to get this extended or better yet permanently implemented!  The only issue I've run into is not being able to attach the image to a DWG file that plain Autocad could read (i.e. a static snapshot).
    Ken
    Valued Mentor
    06-13-2012 02:52 PM in reply to: ravivaish
    A more permanent solution would be to add BING as WMS Service.
    You can if you subscribe to http://register.onterrasystems.com/wms.aspx
    I am not sure how much but at least it is a permanent service...
