• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Board Manager
    Re: Project Artoo for AutoCAD Map 3D Available on Autodesk Labs
    06-21-2012 03:01 PM in reply to: iam_doss
    I have updated the technology preview so it is available in 13 languages - not just English.
    http://labs.autodesk.com/utilities/artoo/
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Please use plain text.
    Board Manager
    01-29-2013 09:51 AM in reply to: iam_doss
    The technology preview will stop working on February 1. I will retire it from Autodesk Labs, Thanks to all who participated.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    tahir.mavric
    06-05-2013 02:26 AM in reply to: scott.sheppard
    Dear mr. sheppard,
    Is there a command to Clean Up a Feature Objects in AutoCAD MAP 3D 2013 (i.e. Geospatial Clean Up)?
    If not, is there any other possibility to Clean Up a Feature Objects (Break crossing)?
    Thanks in advance!
    Best regards,
    Tahir Mavric
    Valued Mentor
    06-05-2013 05:56 AM in reply to: scott.sheppard
    You could use standard clean up tools if the FDO round tripping was seamless. (i.e. Dynamically dumped FDO attributes to object data for editing).
    Imagine this business case:
    You have a dwg with new roads and rivers to add to your SDF.
    You clean up the layers traditionally.
    You push ask that data directly to the sdf since the layer and object data is already mapped.
    You refresh your Sdf and the data is
    there.
    If you miss something, it checks out back into dwg objects with object data, and you can re-clean with clean up tools.
    Why re-invent the wheel, when all we need a fixed FDO dwg integration?
    tahir.mavric
    06-05-2013 06:22 AM in reply to: gluckett
    Dear gluckett,
    Thank you for yout answer.
    You example does not reflect my problem properly.
    We work with industry model data (feature objects) and I would like to check a Area Topology. When Topology reports an error (that the lines intersect), than I would like to break it on intersection.
    I tried to break features lines with drawing Clean Up and BREAK commamd, but didn't make any effect.
    Is it possible to use COGO tools, to break feature lines?
    Has anyone had a problem with this issue before?
    Thanks in advance.
    Tahir
