• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Board Manager
    Project Artoo for AutoCAD Map 3D Available on Autodesk Labs
    1438 Views, 11 Replies
    05-31-2012 07:36 AM
    Project Artoo for AutoCAD® Map 3D 2013 software is a free* technology preview that helps you perform geometry cleanup operations on geospatial data stores to improve the quality and accuracy of your geospatial data.
    http://labs.autodesk.com/utilities/artoo/
    Please trry it and reply to this thread. There is also a thraed in the Civil 3D forum for AutoCAD Civil 3D users who also use AutoCAD Map 3D.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Autodesk, Inc.
    Please use plain text.
    New Member
    Re: Project Artoo for AutoCAD Map 3D Available on Autodesk Labs
    05-31-2012 10:22 AM in reply to: scott.sheppard
    Great idea - I have several clients moving data bak and forth in Map 3D in order to do drawing cleanup. This will help a great deal.
    On the Zero Length Objects. I have an attached SHP file with multiple vertices at one location. Standard DWG cleanup will fix this on an AutoCAD Pline - but this does not seem to be the case here. I'm attaching a sample SHP file for you to test.
    New Member
    06-04-2012 02:22 AM in reply to: scott.sheppard
    After installed the Artoo x64, I cann't find the "new Geospatial Cleanup icon" on Tools tab.
    Is there other method to open it?
    Valued Mentor
    06-04-2012 07:39 AM in reply to: endest
    At the command line type:
    MAPGISCLEAN
    Active Contributor
    06-06-2012 08:56 AM in reply to: scott.sheppard
    Hi, where can I get the available clean operation list for every kind of data source and layer? It seems there are some operations valid for line layers but no for polygon layers. Exists that list?
    Active Contributor
    06-15-2012 03:58 AM in reply to: iam_doss
    Hi, somebody here?
    Board Manager
    06-19-2012 08:05 AM in reply to: iam_doss
    Thnak you for your patience. I have alerted the team that this message has not yet been answered. Our Product Manager associated with the technology preview will be back in the office on June 21.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Autodesk, Inc.
    Active Contributor
    06-19-2012 08:54 AM in reply to: scott.sheppard
    Thank you for your answer. I will wait for.
    Member
    06-19-2012 03:48 PM in reply to: scott.sheppard
    As you've found out, not all cleanup operations will work on all data sources.  In fact, some cleanup operations will only work on certain geometry types. Below is a list of available cleanup operations by geometry type:
    For Lines:
    • Delete Duplicates
    • Break Crossing Objects
    • Extend Undershoots
    • Apparent Intersection
    • Snap Clustered Nodes
    • Zero Length Objects
    • Erase Dangling Objects
    • Erase Short Objects
    • Dissolve Pseudo Nodes
    • Simplify Objects
    • Weed Polylines
    For Polygons:
    • Sliver Polygon Removal
    • Reform Polygons
    For Points:
    • Correct Duplicate Points
    Mark Christian
    Industry Marketing Manager
    Engineering, Natural Resources & Infrastructure
    Autodesk, Inc.
    Active Contributor
    06-19-2012 09:43 PM in reply to: mark.christian
    Thank you
