• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Member
    Printing Options
    116 Views, 6 Replies
    04-15-2012 04:53 PM
    I do not have a plotter.  The largest paper I can print on is 11x17.
    I am needing to create a drawing which can be plotted on A1 size paper.
    How can I get this A1 size to show up in Paper Space so I can use viewports to set up the layout?
    Larry53
    Please use plain text.
    Distinguished Mentor
    thepworth
    Re: Printing Options
    04-15-2012 09:26 PM in reply to: lnelson
    set up the default printer as dwg->pdf (or other PDF creation driver) and set the plotter's default paper size as A1 or a custom size equivalent to A1.
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    *Expert Elite*
    antoniovinci
    04-15-2012 11:06 PM in reply to: thepworth
    Another way to have all formats up to A0 is to add e.g. an HPGL/2 plotter in Windows Control Panel, setting it to plot to "File".
    If you'll really send your drawing to that .PLT file, it will be physically printable in every plotting service in your town, sir.
    New Member
    04-16-2012 02:56 AM in reply to: lnelson
    thanks for the information.
    Active Member
    04-16-2012 08:07 AM in reply to: lnelson
    Thank you!
    thepworth
    04-17-2012 08:19 AM in reply to: antoniovinci
    True, but I know I can open a .PDF to see what "version" of the print I'm sending out.  If I'm storing .PLT files, is there an application to look at them without printing?
    Thanks!
    C3D 2011
    *Expert Elite*
    antoniovinci
    04-17-2012 10:52 PM in reply to: thepworth
    Of course, for free (small preview) and not (full viewer).
