• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Map 3D
    *Aaltonen, Jarkko
    Polygon and Oracle extension problem
    403 Views, 8 Replies
    05-29-2002 09:27 PM
    Hi all!
    I have a problem with "Polygon and Oracle extension".
    I have several thousands (30 000+) of lines and arcs imported from an
    old Finnish GIS application called FinGIS. Those lines and arcs define
    4200+ areas. Some areas are inside the others.
    FinGIS' data was divided into 1sqkm files and it had to cut the lines on
    the file borders and calculate new endpoints for the resulting lines.
    Sometimes this resulted as a small (1mm) gaps between the lines. So with
    AutoCAD I have to do some "drawing cleanup". First "snap clustered
    nodes" with 0.005 tolerance, then "break crossing objects" and "delete
    duplicate objects". Finally I am able to create a polygon topology
    without any errors.
    Now I use "Polygon and Oracle extensions" "convert topology to polygons"
    -function to create Oracle-type polygons on a new layer. Everything
    seems to work fine and I get the areas I wanted with the islands correct
    and all.
    Now the problem occurs when I try to write these to Oracle. Over 4000 of
    these areas are exported just fine but 140 of them cannot be exported.
    The error message says something like "AutoCAD cannot export unbalanced
    mpolygons to Oracle". Is there any "official" explanation on what does
    this "unbalanced mpolygon" actually mean?
    With a help from our Finnish reseller/distributor Viasys we've noticed
    that the problem areas all have arcs on them. According to Viasys
    AutoCAD has generated the new areas so that the arc and the line
    actually create a new really really small area, meaning that the line
    and the arc actually cross each other again, even though I managed to
    create a topology without any errors!
    So where is the real problem, in topology creation or in polygon
    creation or in both, and what do I do to get rid of it?
    I really hope you understand what I mean.
    At first the new "Polygon and Oracle extension" looked really good. It
    was exactly what I wanted. However this problem means that I have no use
    for it after all.
    j.
    Jarkko Aaltonen
    City Survey Department
    City Of Tampere
    Finland
    Please use plain text.
    *Bell, Andrea
    Re: Polygon and Oracle extension problem
    05-31-2002 03:25 AM in reply to: *Aaltonen, Jarkko
    Hi Jarkko,
    I believe the answers to most of your questions can
    be found in the Polygon and Advanced Oracle Extension Help (the question mark on
    the Extension tool bar).  You asked "what does unbalanced Mpolygon
    actually mean?", from the Help file:
    style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">
    face=Arial size=2>Balancing - Process where the polygon object recalculates
    which boundaries are outer or inner. Boundaries are designated as inner or outer
    when the polygon is created and when new boundaries are added to the
    object.
    face=Arial size=2>
    face=Arial size=2>You can edit the polygon object to rebalance it and then you
    should be able to export to Oracle.  Please see Mpolygon>Rebalancing in
    the Autodesk Map Polygon and Advanced Oracle extension Help.
    Andrea Bell
    GIS Product Support
    Technician
    > Hi all!
    > I
    > I have several
    > old Finnish GIS
    > 4200+ areas.
    > without any errors.
    > Now I
    > and all.
    cannot be exported.
    mean?
    noticed
    Viasys
    mean.
    good. It
    have no use
    > for it after all.
    > Thanks,
    j.
    > Jarkko Aaltonen
    > City Survey
    Department
    > City Of Tampere
    > Finland
    *Aaltonen, Jarkko
    Re:
    05-31-2002 09:37 PM in reply to: *Aaltonen, Jarkko
    Andrea Bell wrote:
    > Hi Jarkko,
    > I believe the answers to most of your questions can be found in the
    > Polygon and Advanced Oracle Extension Help (the question mark on the
    > Extension tool bar). You asked "what does unbalanced Mpolygon actually
    > /Balancing - Process where the polygon object recalculates which
    > outer when the polygon is created and when new boundaries are added to
    > the object./
    > You can edit the polygon object to rebalance it and then you should be
    > able to export to Oracle. Please see Mpolygon>Rebalancing in the Autodesk Map Polygon and Advanced Oracle extension Help.
    > Regards,
    > Andrea Bell
    > GIS Product Support Technician
    Hi!
    Thank you for your reply. However, in this case rebalancing doesn't
    help. I still can't export the objects to Oracle and I get the same
    error message: "Cannot export an unbalanced MPolygon object. etc".
    And even if I could export them it really wouldn't help much since the
    original problem would still remain: Why does this happen? I've always
    thought that if I am able to create a polygon topology I can also expect
    that my data is correct and there are no crossing lines for example. But
    after I create the mpolygons from that same topology my data is
    suddenly incorrect. I ask again: why?
    j.
    *Aaltonen, Jarkko
    Re:
    05-31-2002 09:50 PM in reply to: *Aaltonen, Jarkko
    An addition to my previous post.
    If I explode one of the unbalanced mpolygons to lines and arcs, then do
    a drawing cleanup with "break crossing objects" -option I get this:
    Modified object(s) :0
    Deleted object(s) :0
    Created object(s) :0
    So, it tells me that there are no crossing objects, right?
    After this I use "pedit" to create a new closed polyline from the lines
    and arcs. When I try to create a new mpolygon from this polyline I get this:
    One boundary was rejected because it crosses.
    So there is a crossing after all. Why don't the drawing cleanup find it?
    Why am I still able to create a polygon topology? Is there something
    wrong in the accuracy of the drawing cleanup tool?
    j.
    *Christian, Mark
    Re:
    06-03-2002 03:03 AM in reply to: *Aaltonen, Jarkko
    Hello Jarkko,
    Can you please post your dwg to the customer files group? I would like to
    take a look at this problem in more detail.
    Thank you,
    Mark Christian
    GIS Product Support
    Autodesk, Inc.
    "Jarkko Aaltonen" wrote in message
    news:3CF8C2FE.6090903@tt.tampere.fi...
    this:
    > j.
    *Aaltonen, Jarkko
    Re:
    06-03-2002 03:20 PM in reply to: *Aaltonen, Jarkko
    Mark Christian wrote:
    > Hello Jarkko,
    > Thank you,
    > Mark Christian
    > GIS Product Support
    > Autodesk, Inc.
    Hi!
    It should be there now. The subject line is "Polygon and Oracle
    extension problem sample"
    Dwg includes only one area but you should be able to reproduce the
    behaviour I described in my previous message.
    Shortly:
    - drawing cleanup does nothing
    - pedit creates a closed polyline
    - cannot create mpolygon because "the polyline crosses"
    j.
    *Christian, Mark
    Re:
    06-04-2002 07:06 AM in reply to: *Aaltonen, Jarkko
    Thank you Jarko.
    I'll take a look and give you an update ASAP.
    Mark
    news:3CFC5C22.4060705@tt.tampere.fi...
    > > Hello Jarkko,
    to
    > > Thank you,
    > > Mark Christian
    > > GIS Product Support
    > > Autodesk, Inc.
    > Hi!
    > Shortly:
    > j.
    *Aaltonen, Jarkko
    Re:
    06-09-2002 05:35 PM in reply to: *Aaltonen, Jarkko
    > Thank you Jarko.
    > Mark
    Hi!
    It has now been several days since your last message.
    My guess is that you were actually able to reproduce the behaviour I
    described and that you have no idea what causes it or how to get rid of it.
    I think it is safe to say that I found a bug in your software. A bug
    that makes the whole "Polygon and Oracle extension" totally useless.
    Please tell me that I am wrong.
    j.
    New Member
    03-30-2012 07:21 AM in reply to: *Aaltonen, Jarkko
    almost ten years later, a can tell that your problem with unbalanced Mp are originated becaus of using arcs. try to replace 'em with lines, build your polygon and try to upload it to oracle... voilá!. Don´t know who to blame Mr.Map.. or Mr.Ora. regards
