• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Member
    North9ON
    Pasted Excel Table in Map 3D 2011 - Text Disappears for Second User
    226 Views, 2 Replies
    02-22-2012 06:11 AM
    I created some tables in the attached AutoCAD Map 3D 2011 drawing by copying and pasting cells from an Excel 2007 workbook.
    I have been able to update the tables in AutoCAD and print without any problems. However, when a second user opened the drawing, the table text was missing (the lines were present).
    Any idea what may be wrong with the drawing and how to fix it?
    Note: We are saving our files in AutoCAD 2010 format for compatibility with some LT users.
    Please use plain text.
    Distinguished Mentor
    thepworth
    Re: Pasted Excel Table in Map 3D 2011 - Text Disappears for Second User
    02-23-2012 06:12 PM in reply to: North9ON
    Do both machines have the same level of ODBC drivers installed?
    Check Control Panel - Administrative TOols - Data Sources - Drivers Tab - see if the version is the same for both.
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    Active Member
    North9ON
    02-24-2012 06:42 AM in reply to: thepworth
    I'm running Windows 7 64-bit and he is running Windows XP. I will check on the drivers.
