• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Re: Object Data
    04-27-2012 02:13 PM in reply to: MorganMcGuire
    Has there been any update to this problem? I wish to do the same thing but cannot find any info online if it is possible or how to change the order other than alphabetical.
    Please use plain text.
    Valued Mentor
    Re: Object Data
    04-28-2012 02:33 AM in reply to: philsla
    Don't know anything about Mapinfo other than it just a data base on a map program like Map or esri type of thing  so forgive me if this is out to lunch
    So why fight the system?
    name your fields alphabeticaly, i.e a list of animals
    a_Zebra, b_Cat, c_Pig, d_Elephant, e_Snake, etc
    The data is in the order the client wants.  You don't have to work any to hard to supply the information requested.  You export it simply, directly and it's gone. I ran a quick test opening the Mapinfo *.tab in Tatuk and it looks ok to me.
    Put in a alias field for the display name if Mapinfo can use it,  i.e the first fields would be Zebra, Cat, Pig, etc
    or maybe inport into an empty mapinfo data table with the field alias names at the heads of the columns?
    Dave
