• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Contributor
    Object Data Attachments
    93 Views, 5 Replies
    11-26-2002 06:33 PM
    Hello
    2 questions re Object Data Attachments
    1) We want to attach dwg files as documents to object data but find that this method launches another session of AutoCAD. Is it possible to have this drawing file open in the current session?
    2) Similarly we are attaching Word Documents to object data but the document fails to open because there are spaces in the path name. Is there a setting that controls spaces in path names or do we have to change our directory names?
    Many thank for any answers,
    Neil Carstairs
    Cartographical Surveys Ltd.
    (UK)
    Please use plain text.
    *Garnett, Kevin W.
    Re: Object Data Attachments
    11-26-2002 09:55 PM in reply to: csoffice
    Would a simple hyperlink work better for
    you in either situation?
    Hello
    session?
    directory names?
    Neil Carstairs
    (UK)
    Active Contributor
    Re:
    11-27-2002 03:46 PM in reply to: csoffice
    Tried that, so next question is,
    with pickfirst set to 1 and both hyperlink
    options checked on how do I pull up the
    hyperlink menu (the hyperlink attach worked fine)
    Neil Carstairs
    (UK)
    *SIS
    11-27-2002 05:13 PM in reply to: csoffice
    Hi,  Did you try enclosing the path
    in double quotes. I remember it worked for me some time back..
    Hello
    session?
    directory names?
    Neil Carstairs
    (UK)
    *Garnett, Kevin W.
    Re:
    12-02-2002 12:11 AM in reply to: csoffice
    Select the object, right click, and it should be at
    the bottom of your right click menu, unless you have right click configured to
    repeat the last command, then I am not sure.
    Tried
    attach worked fine)
    Neil Carstairs
    (UK)
    Active Contributor
    Re:
    12-04-2002 06:32 PM in reply to: csoffice
    I think I have sorted this.
    Pickfirst needs to be 1, both
    hyperlink boxes need to be ticked
    and then tick on the Windows Standard
    Behaviour option for Shortcut Menus in
    Drawing Areas. The Hyperlink menu then
    appears as part of the short cut menu.
    Neil Carstairs
