• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    New Member
    OLE spreadsheet plotting black
    218 Views, 1 Replies
    07-30-2012 09:31 AM
    I am using AutoCAD Map 3D 2011 and I am plotting a map with transparent polygon features as well as an Excel spreadsheet inserted as an OLE object. When I plot with transparency turned off (in the _plot dialogue box) the spreadsheet is white but the features are solid. When I plot with transparency turned on, the features look great, but the spreadsheet has a black background with white text.
    Any idea how to get the spreadsheet to keep a white background while plotting transparency is turned on? I have tried changing the background of the spreadsheet to 254, 254, 254 with no change in the results.
    thanks-
    Please use plain text.
    New Member
    Re: OLE spreadsheet plotting black
    07-30-2012 10:28 AM in reply to: mnevans_5
    I think I may have found the solution. I had to change the object type in the properties of the OLE object from "monochrome (spreadsheet)" to " high graphics (photo)."
    CAD can be so obtuse sometimes...
