AutoCAD Map 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
OD-ROADS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am going through autocad map tutorial and trying to export Redding map .dwg to sdf format....when openning the properties of ROADS ...at the bottom of the properties table you get something like that:
OD-ROADS
Lentgth....
Name...
ST_Name...
ST_type...
So my problem is how you do to put the OD in the properties there? can someone guide me?
Re: OD-ROADS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
when you export select the feature class tab, select attributes button and select properties and object properties you want to be object data for the sdf objects.
Re: OD-ROADS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
THANKS.,,,Mr parkr4fst
but the problem is do i have to make table for those details?
Re: OD-ROADS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Data connect to the sdf and open the data table.
back up a bit and tell us your original roads are autocad polylines or line with object data attached? If so, then that data becomes the data in the sdf file. If not then you have not data in the table.
Re: OD-ROADS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
after checkiing I found that most of the lines are polylines and some are simply line
Re: OD-ROADS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
selct a pline or line and check the properties. Ctr1 or right click and properties. at the bottom of the properties you have OD:nameofdatatable. Are there values in the right column of the OD?
If so this is exported to the sdf when you select to do so in the export process
Re: OD-ROADS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks a lot for assistance
