• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Distinguished Contributor
    No extent in drawing
    435 Views, 15 Replies
    10-31-2007 03:32 PM
    Has anyone got an err like this before?
    My Zoom Extents isn't working right and when I try to plot it says, "No extents in drawing. Could not set plot area to Extents." If I hit OK and go to the Plot Window, Extents isn't an option for the Plot Area and the Plot Scales are way off.
    I have never seen a drawing that didn't have an extents?
    Any suggestions?
    Please use plain text.
    *James Murphy
    Re: No extent in drawing
    11-02-2007 06:50 AM in reply to: cedwards
    What is returned when you type in EXTMIN and EXTMIN ?
    Are you in model space or paper space? On a Layout tab or the model tab?
    Murph
    The world is not FLAT so why is your GIS data?
    http://map3d.wordpress.com
    wrote in message news:5766254@discussion.autodesk.com...
    Any suggestions?
    11-15-2007 08:37 AM in reply to: cedwards
    Someone solved the problem for me.
    I don't really understand what happened, but it was fixed by going into all of the layouts, making sure they were set to paper space, and zooming to the extent. After I did that to all 30+ layouts, the zoom extent worked fine in the Model Layout.
    Thanks for your help.
    01-16-2008 09:55 AM in reply to: cedwards
    When I Zoom Extents, it goes way too far out, way past anything that is drawn in. Like out to the entire world when all I want and have is one town.
    Command: extmin
    EXTMIN = -1.00E+20,-1.00E+20,-1.00E+20 (read only)
    Command: extmax
    EXTMAX = 1.00E+20,1.00E+20,1.00E+20 (read only)
    Valued Contributor
    11-17-2011 04:30 PM in reply to: cedwards
    I have a dwg that when I Zoom Extents, it also goes too far out.
    I have tried all of the trick that typically solve this (Erasing all but the selected objects, Audit, Purge) and even stripped everything out of the drawing one thing at a time and didn't find anything.  There is nothing left in the dwg and it sill does it.
    The odd thing is that now when I enter Erase All, it says:
    3 found
    3 were filtered out
    There seems to be three objects in this dwg that I cannot select/read/edit.  Also, when I open the Design Center, there are a bunch of blocks (looks like tick, arrows, and some text blocks) that I can't get rid of.
    This is not a dwg that I can just Wblock and create a new file, because there are many database connection, custom visual settings, layouts, etc. that I don't have the time to recreate.
    Any Suggestions?
    *Expert Elite*
    11-17-2011 08:39 PM in reply to: edwa8511
    you have 3 non-graphical entities in the modelspace:
    MAPBULKFEATURE, MAPGISLABES, MAPGISLAYERBITMAP ... these are all Map3D-objects and yes, you are right, you can't delete them with _ERASE.
    What you can do:
    save this drawing as DXF file
    open the DXF file with an ascii-editor (e.g. Notepad++, Notepad would also be possible, but a little bit slow)
    search for the part:
      0
    SECTION
      2
    ENTITIES
     0 MAPBULKFEATURE 5 131117 330 17
     And start erasing at the red marked lines up to this part:
    100 AcMapGisLayerBitmap 70 1
      0
    CIRCLE
      5
    22DC03
    330
    17
    100
    then save the file and open it with AutoCAD. ==> now ZoomExtents works.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    *Expert Elite*
    antoniovinci
    11-17-2011 11:40 PM in reply to: alfred.neswadba
    I love this Cad "surgery", Herr Alfred.. Wuenderbar!
    *Expert Elite*
    11-18-2011 12:50 AM in reply to: antoniovinci
    and getting your answer (thank you) I saw that the formating of the red part of the DXF (the lines to be erased) where reformatted in a way that is wrong, sorry for that! (and now I can't modify that ;( )
    @edwa8511:
    Please compare the lines between your DXF and my attachment!
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    11-18-2011 09:27 AM in reply to: alfred.neswadba
    This worked great on the stripped down dwg, but the original with all of its complexity is causing problems when trying to reopen the .dxf in CAD.  It keeps crashing.
    When I save the dwg to a dxf, I got it to open it before I edited it.  If I try to open it after making your changes, CAD shuts down.
    I am trying to edit the dxf with Notepad, is there something better to use?
    *Expert Elite*
    11-18-2011 10:41 AM in reply to: edwa8511
    As mentioned, Notepad is not built for large files, try Notepad++ instead, downloadable >>>here<<<
    - alfred -
    Alfred NESWADBA
