• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Valued Contributor
    Re: No extent in drawing
    11-18-2011 11:26 AM in reply to: alfred.neswadba
    I have installed Notepad++, I am amazed that I didn't need IT for that..Thanks.
    I opened the dxf and tried to delete those lines, but when I try to open it in CAD, I get:
    The following error was encountered while reading
    in SEQEND starting at line 828316:
    Premature end of object
    Invalid or incomplete DXF input -- drawing discarded.
    I don't know enough about this language to understand what the problem is.  I didn't start editing until line 828325.
    Please use plain text.
    11-18-2011 11:40 AM in reply to: edwa8511
    it's hard to say what you did or what is wrong with this part of the DXF-file.
    At least you have a line-number and I would first look to this line ... plus a few lines above and below. Of course I understand that replacing parts of the file needs knowledge about how DXF is structured. Deleting one line on the wrong place can cause big troubles and in most cases the DXF is then not readable anymore.
    Can you upload this DXF (zipped)?
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    11-21-2011 02:15 PM in reply to: alfred.neswadba
    I don't know if I got this small enough to attach, but I will give it one more try.
    I really appreciate your help..Thanks.
    11-21-2011 02:28 PM in reply to: edwa8511
    find attached a version, that does ZoomExtents like it should. Please verify first all your dataconnections before deleting your previous file!
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    11-21-2011 04:36 PM in reply to: alfred.neswadba
    You Are The Man...
    That's Great.
    Did you have to do anything different than what you had explained to me earlier?  I have at least one other drawing with the same problem and will try to fix them later.
    Thanks for all the help.
    11-21-2011 10:59 PM in reply to: edwa8511
    No:smileywink:
    - alfred -
    Alfred NESWADBA
