• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    New Member
    New guy with some questions
    97 Views, 1 Replies
    05-03-2012 11:42 AM
    Hi! My background is in architectural drafting/CAD, and I am being nudged into GIS at my firm. I have a lot of AutoCAD experience, so going though the Map3D tutorials was not a problem...but those tutorials don't answer some BASIC questions I have.
    #1- When starting a new map from scratch, what should I set the units to? Should they stay at decimal? Engineering? Architectural? Any recommendations for changes to the Standard Settings before I start drawing?
    #2- should I assign a Coordinate system immedately before drawing, or can I do it afterwards, and then "move" the geometry to the correct coordinates?
    #3- When I draw, should everything be done in inches, as Civil Drafters do? Or should I be working in Feet, and real world sizes; this is what our County GIS people want when we submit drawings to them in the future.
    #4- Where can I get some georeferenced photos of my region? I understand that if a coordinate system is set and if the photos are georeferenced that they should Automatically "snap" into place for easy tracing.
    #5- Is there anyone out there using Map 3D in California?
    Thanks!!
    Please use plain text.
    Valued Mentor
    Re: New guy with some questions
    05-03-2012 12:36 PM in reply to: archdrafting
    set the coor system first along with any drawing layers you would use in each map you draw and save it as a template file so you con start a new drawing with all those items set as you like them
    Units are relative to the CS you select. some are metric in meters; some are in feet indicated by the "F" in the Coord sys name  CA83-IF is cal state plane in feet . I'm not sure what part of the state that is in.
    http://www.dot.ca.gov/hq/tsip/gis/datalibrary/gisdatalibrary.html   has all sorts of downloadable GIS data
