• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    New feature from geometry
    237 Views, 4 Replies
    06-21-2012 11:17 AM
    I am editing a shape file and have encountered a warning which reads "The selected acdb entities are not connected". Any ideas on how to check which entity this warning is trying to connect to?
    Please use plain text.
    *Expert Elite*
    Re: New feature from geometry
    06-21-2012 12:33 PM in reply to: dkent
    has anyone tried to work "offline" with that data (that drawing)?
    If so there are cloned objects in the drawing and these objects can't find there original data .... just a guess, but if you can describe more detailed when this happen, with what type of data, at what command, .... the guessing will be more easy:smileywink:
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Product Support
    borycep
    06-26-2012 03:26 PM in reply to: dkent
    This error sometimes appears when running Create from Geometry on multiple objects, but it might appear in other contexts. You might know this already, but if you run MAPCREATEFEATUREFROMGEOMETRY on multiple objects, the program tries to create a single Map Feature.
    • You might analyze your selection -- maybe there is an issue with the geometry itself -- e.g., if polygons, are they closed?
    • Or have you inadvertently enabled Persistent Locking?
    • Or would running MAPCHECKINALL and doing a quick disconnect/reconnect to the feature source solve this?
    Phil Borycens
    Support Specialist
    AEC Infrastructure
    Autodesk, Inc.
    Product Support
    borycep
    06-27-2012 12:17 PM in reply to: borycep
    One more thing I forgot to mention...
    You can also delete the IDX file associated with your SHP to try to resolve this issue.
    The IDX (index file) will get recreated by AutoCAD Map 3D next time you connect with the shapefile.
    Sometimes that fixes issues like this one.
    Thanks!
    Phil
    Phil Borycens
    Support Specialist
    AEC Infrastructure
    Autodesk, Inc.
    Member
    01-16-2013 02:06 PM in reply to: dkent
    Thank you for the input. I deleted the idx file and it fixed my problem.:smileyvery-happy:
