• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Contributor
    New Map background color in AutoCAD Map 2013...
    648 Views, 4 Replies
    06-15-2012 04:42 AM
    Don't works for me. I have changed this new property for some Maps but AutoCAD Map always displays the default background color that I set up in AutoCAD Options. Any trick?
    Thanks in advance
    Please use plain text.
    Product Support
    borycep
    Re: New Map background color in AutoCAD Map 2013...
    06-18-2012 04:34 PM in reply to: iam_doss
    Can you please reply with a set of steps to reproduce this issue?
    Thanks!
    Phil
    Phil Borycens
    Support Specialist
    AEC Infrastructure
    Autodesk, Inc.
    Active Contributor
    06-19-2012 01:13 AM in reply to: borycep
    Hi Phil, thank you for your answer
    See attached Video
    Product Support
    borycep
    06-19-2012 10:36 AM in reply to: iam_doss
    Thank you for the video.
    I tested this myself, and replicated the issue on my system. It appears that the background color assignment is not respected by the program after creating a new display map, assigning a background color to it, and associating it with a viewport.
    I did some research internally, which led me to find out that our development team has been investigating this issue. The good news is that they have developed a codefix to resolve this issue. This fix, unfortunately, is planned for release in a future service pack, and I do not have information regarding if/when this service pack might be released.
    I have linked your case to the change request for the issue, which will bring further attention to it.
    Thank you for reporting the issue to us.
    Phil Borycens
    Support Specialist
    AEC Infrastructure
    Autodesk, Inc.
    Active Contributor
    05-15-2013 11:11 PM in reply to: borycep
    Hi. Any news about that? Same problem in AutoCAD Map 2014. Thanks
