• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Distinguished Contributor
    Nation Map Seamless Viewer help
    176 Views, 3 Replies
    07-03-2012 12:26 PM
    I downloaded and unzipped the files and I've assigned a Zone.
    How do I get the aerial into Civil 3D 2013?
    2013 Civil 3D
    Please use plain text.
    Re: Nation Map Seamless Viewer help
    07-03-2012 12:42 PM in reply to: ktm125
    what type of files have you downloaded?
    If they are standard GIS-files then you would have the option:
    • command _MAPCONNECT
    • or if it's raster-images I would preferre the usage of _MAPIINSERT.
    - alfred -
    Alfred NESWADBA
    07-03-2012 12:55 PM in reply to: alfred.neswadba
    .dbf
    .idx
    .prj
    .shp
    .aux
    .xml
    .html
    .txt
    .adf
    .dir
    .dat
    .nit
    don't know which file to select under mapiinsert command
    2013 Civil 3D
    07-03-2012 01:10 PM in reply to: ktm125
    I wrote that you can use _MAPIINSERT for raster-images, well, I meant colorized raster images), sorry for beeing not clear enough.
    Within your list I see:
    • SHP that can be connected with command: _MAPCONNECT (btw: delete the IDX-file before referencing the SHP into your Map3D-session).
    • ADF, also this can be connected with _MAPCONNECT (it's raster, yes, but not colorized raster, it's a type of elevation-model). You can look to >>>this page<<< for how to use it.
    • I don't know what's behind DAT or DIR or NIT, but the others have no direct data, just info like projection-systems, index-file, ...
    - alfred -
    Alfred NESWADBA
