• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    *Jason Heyman
    Match rotation
    116 Views, 5 Replies
    01-30-2007 07:50 AM
    A few version ago autocad had a function that would allow you to pick one
    line and match the same bearing to any other line you selected. My question
    is does this function still exist and if so, how can I do it?
    Autocad Map 2007
    Please use plain text.
    *melanie stone
    Re: Match rotation
    01-30-2007 07:56 AM in reply to: *Jason Heyman
    would that be the ALIGN command?
    Melanie Perry
    ***not all who wander are lost***
    http://mistressofthedorkness.blogspot.com/
    "Jason Heyman" wrote in message
    news:5468603@discussion.autodesk.com...
    Autocad Map 2007
    *James Murphy
    Re: Match rotation
    01-30-2007 08:08 AM in reply to: *Jason Heyman
    IIRC it was an old express tool, that got dropped when Matchproperties was
    ported into the core AutoCAD. The closes thing to it is using the properties
    palette and quickcal with an expression.
    Murph
    The world is not FLAT so why is your GIS data?
    http://mappingitout.blogspot.com/
    "melanie stone" wrote in message
    news:5468654@discussion.autodesk.com...
    Melanie Perry
    Autocad Map 2007
    *Jason Heyman
    Re: Match rotation
    01-30-2007 08:10 AM in reply to: *Jason Heyman
    No, this was just a simple express tool where you could just click a line
    and every other line you selected would match the same bearing. Align is not
    really what I am looking for.
    Melanie Perry
    Autocad Map 2007
    *melanie stone
    Re: Match rotation
    01-30-2007 08:12 AM in reply to: *Jason Heyman
    in 2006 at least the Align command is to be found under the Modify menu.
    well, that's goofy... it's under Modify > 3D Operation (but the prompt in
    the taskbar says 2d and 3d alignments)
    Melanie Perry
    "James Murphy" wrote in message
    news:5468664@discussion.autodesk.com...
    Murph
    Melanie Perry
    Autocad Map 2007
    *melanie stone
    Re: Match rotation
    01-30-2007 08:13 AM in reply to: *Jason Heyman
    right. sorry. that one would give it the same angle, but, would physically
    move it and you don't want that.
    Melanie Perry
    news:5468688@discussion.autodesk.com...
    Melanie Perry
    Autocad Map 2007
