• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Valued Contributor
    Mapimport Error - "Can't open object for read"
    119 Views, 0 Replies
    04-17-2012 10:36 AM
    Hi All,
    I have recently run into a problem when importing objects into Map (_mapimport command).  My system info is: Map3D 2010 32 bit with service packs 1 and 2 on Windows XP 32 bit with service pack 3.  PC has 4 GB RAM and dual core 2.79 GHz processor.
    What I am needing to do is import some data from shapefiles for use in a drawing.  However, I only need a limited portion of the files, so I am using the "define window" in the import options to specify the location in the map.  However, when I click on OK to run the import, I get a few objects imported then get the error "can't open object for read" (see the screen shot).
    I have tried a few things to trouble shoot:
    Opened same shape file in ArcMap - no problems
    Import entire shapefile into Map3D without any data - no problems
    Import entire shapefile into Map3D with data - no problems
    Connect to shapefile via FDO - no problems
    Import entire shapefile into a different drawing, then query into original drawing in the limited area - no problems
    I only encounter this error if I use the mapimport and try to limit the area of the import; either by defining the area or by using the "use display" filter.  This error also occurs on only a few shapefiles, but not all of them.  I have also tried using recover and audit on the DWG, but they both come up clean.  If anyone has any ideas, I would appreciate it.
    Norm
    Please use plain text.
