AutoCAD Map 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Map3D fails on startup. Please help!!!
- Highlight
- Email to a Friend
I am working in autocad Map3D 2012
My computer is running windows XP service pack 3 (3GB switch enabled)
2012 version of Map installed on July 14th, map3d 2011 still works fine.
I start autocad and i get this error message in the command line.
c:\program files\autodesk\autocad map 3d 2012\acmapdwfapi.arx cannot find a
procedure that it needs.
.Failed.
AcMapWorkspace.arx Load Failed
AcMapDwfApi.arx Load FailedRegenerating model.
c:\program files\autodesk\autocad map 3d 2012\acmaploader.arx cannot find a
c:\program files\autodesk\autocad map 3d 2012\bin\tbexporter.arx cannot find a
AutoCAD menu utilities loaded.*Cancel*
Command: COMMANDLINE
Command: _RIBBON
Command: properties
Command: _MAPSTARTWSPACE
I dont know what to do!!! Can anyone please help?
Re: Map3D fails on startup. Please help!!!
- Highlight
- Email to a Friend
Okay i fixed a couple of the things by copying files from a working version. but my taskpane still wont come up, mapwspace is an unknown command. acmaploader.arx is still failing. and so is topobase. any ideas?? ive replaced the files still nothing.
- Highlight
- Email to a Friend
also, my planning and analysis workspace is gone?
- Highlight
- Email to a Friend
It sounds like your CUI isn't loading right. You could either reinstall, or transfer in the Planning and Analysis CUIX file, then load it as a partial. You would likely want to do the same for the Maintenance CUIX - that should bring back all the Map commands that you are missing.
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
