• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    Sam-I-am
    Map3D 2013 tutorial
    697 Views, 2 Replies
    08-01-2012 11:06 AM
    In Tutorial: Working with Industry Models
    Exercise 2: Import Data into the Industry Model,
    I am supposed to go to the insert tab and run convert to industry modle.
    however it does not exist in this tab, I could not get the help file to show be where I could find this command.
    any suggestions
    also where is the dataset for this module. I followed the link from the help file to
    http://docs.autodesk.com/MAP/2013/ENU/ but could not see any data set for this module
    Please use plain text.
    Employee
    sebastien.baudin
    Re: Map3D 2013 tutorial
    10-02-2012 02:36 AM in reply to: Sam-I-am
    You have to be in the "Maintenance Workspace" to be able to see the "Convert to Industry Model":
    For your second question, you can find some template under:
    ...\Program Files\Autodesk\AutoCAD Map 3D 2013\Sample\
    Kind Regards,
    Sébastien Baudin
    Autodesk Support Team
    New Member
    01-11-2013 02:41 PM in reply to: Sam-I-am
    I checked my dataset for industry model tutorial
    :\Program Files\Autodesk\AutoCAD Map 3D 2013\Sample\Maps\SDF
    those data is not match the Exercise 2: Import Data into the Industry Model. I don't have CONDUCTOR.sdf and SERVICE_POINT.sdf and TRANSFORMER.sdf
    DO anyone know where I can find those data files ?
