AutoCAD Map 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Map Features Unselectab le
- Highlight
- Email to a Friend
- Report Inappropriate Content
When I use quick select, I can see that there are map features listed in my drawings. When I try to select these features it either says they have been selected but they aren't actually selected, or the autocad will crash forcing me to start over. How can I removed these features (which do not actually appear in the drawing) from the drawing. So many of my files seem to have this problem.
-N
Re: Map Features Unselectab le
- Highlight
- Email to a Friend
btw, I am using Map 2010 32bit. I can't deny there are days where I want to go back to '08 standard. I have been very disappointed in Map. It seems to offer a lot but really doesn't seem to handle all that it says it can.
- Highlight
- Email to a Friend
What kind of file are you connected too?
Are your shapes Polygons, points, or lines?
- Highlight
- Email to a Friend
Check the task pane if there are any layers (feature classes) present in it (If it's turned off type mapwspace in the command line then press enter twice).
If there are no feature classes there, check the connect to data dialog (Task Pane > Data > Connect to data). If there are map features connected to your drawing, you should see them there. Disconnect, then delete the connections, save the drawing and you should be alright from there.
If this happens every time you start a drawing -create a new drawing with the new command-, then it should be the dwt, that you choose when creating a new drawing. Open the dwt and do the same to it.
Hope this helps, G
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Hasve you tried the _purge command and purge regapps?
Supportting the troops daily.
