• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Contributor
    Map Crashes with DWG
    381 Views, 11 Replies
    08-14-2012 12:59 PM
    Hi, I'm using Map 2013, I have Windows 7 and I am using th 64 bit version of Map.  I have a dwg with 3 mpolygons, so the drwaing size is very small.  But whenever I try to open this drawing I get the Fatal Error: Unhandled Access Violation Reading 0x0030 Exception at  d446952ch.  I have attached the drawing if anybody wants to take a look.
    Thank you,
    Michael Kohelr
    Please use plain text.
    *Expert Elite*
    Re: Map Crashes with DWG
    08-14-2012 01:21 PM in reply to: mekohler
    I have not had any problem opening your dwg. I did a _AUDIT ==> no errors.
    I saved it with a new name and attached it here, can you open now what I saved?
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Active Contributor
    08-14-2012 01:32 PM in reply to: alfred.neswadba
    No, I get the same error.  I've been reading that mpolygons are causing crashes on 64 bit machines.  I'm going to install 2010 32 bit and see if it still works.  All I'm doing is getting rid of donuts in a drawing containing closed polygons.  Instead of creating a topology and subtracting the polygons, I have a seperate drawing with the closed polygons.  I then delete and copy and paste the correct polygons from this drawing.  I have to do this once a month.
    But thanks for the effort.
    Michael Kohler
    *Expert Elite*
    08-14-2012 01:37 PM in reply to: mekohler
    I read and wrote your file with Map3D2013/64bit German on Win7/64bit Enterprise (SP1+updates up to now installed).
    I have admin-rights, maybe that can be a help for you.
    You may also try to create a new user-account with admin-rights on your worstation and try Map3D then again.
    - alfred -
    Alfred NESWADBA
    Valued Mentor
    LisaPohlmeyer
    08-14-2012 02:02 PM in reply to: mekohler
    I'm using Win 7-64 and Civil 3D 64bit, I can open your drawing fine.  Perhaps repairing your install?  Or as Alfred suggested, running as Administrator.
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
    Active Contributor
    08-15-2012 10:08 AM in reply to: LisaPohlmeyer
    There's something about mpolygons that crashes map for me.  I've done a reinstall and have followed the advice in a few other threads, i.e. I've turned off the properties dialogue box.  It's not just the dwg file I've attached.  I've created a simple polgon topolgogy, with 3 polygons, and I as soon as I convert topology to mpolgyons Map crashes.
    I have to convert a shapefile to a sdf 2 to publish in Map Guide 6.5.  The reason I use mpolygons is to get rid of some internal islands.  Is there another way of doing this?  I've used a FDO connection to connect to the shapefile, but I can't export it.
    Michael Kohler
    Valued Contributor
    10-23-2012 09:24 PM in reply to: mekohler
    I have the same issue with Civil 3D 2013. I run it on my laptop and the issue is simple. I draw a rectangle, I try to create a polygon using MPolygon and it creates it. When I exit the command and I try to hover over the polygon, the cursor stops at the edge of the polygon and fatal errors. What graphics card do you use? I run a switchable based on Intel and AMD.
    Ishka
    CAD Manager
    Tom Groll Engineering
    www.tg-eng.com
    Email: ishka@tg-eng.com
    Blog: http://www.civildigest.com
    Twitter: C3Dish
    Windows 7 x64
    IDS 2014, 2013 & C3D 2012
    Intel i7 930 @ 2.8Ghz
    12GB RAM
    Nvidia GeForce 9600GT
    *Expert Elite*
    10-24-2012 05:15 AM in reply to: ishkav
    Try to disable ROLLOVERTIPS first and if that is not enough also disable SELECTIONPREVIEW. Let us know if this avoids crashing Map.
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    10-24-2012 06:29 AM in reply to: mekohler
    Looks like the rollovertips is the culprit. The thing is that I believe it is tied to the videocard, since I can try the same on another machine that let's say has a Nvidia and I did not get any issues with rollovertips on. So I guess we should all look into certified video cards from now on?
    Ishka
    CAD Manager
    www.tg-eng.com
    Twitter: C3Dish
    Windows 7 x64
    12GB RAM
    *Expert Elite*
    10-24-2012 06:37 AM in reply to: ishkav
    Maybe? I would start disabling the hardware-acceleration + give us the info what GC you have (including driver-version and what OS you are running).
    - alfred -
    Alfred NESWADBA
