- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I have an existing map book system that covers a City. I am currently going through a review process to make sure that everyone who will be using it is happy with the layer before we spend any money producing the books. My last comment was to change a particular hatch pattern within the actual map book template. Specifically, to change the hatch inside the north arrow from it's current pattern to a solid fill.
I went in and opened the map template I am using to generate the map sheets. The arrow block is a part of the overall title block, but I went in to the block editor and successfully made the changes. I then saved the file, keeping it as a dwt.
Obviously this change won't be immediately implemented in the actual map book, so I went ahead and re-built the map book. When this finished, I noticed that the hatch pattern in the north arrow had not changed, so I went back and re-built the map book again, but choosing the option to "edit settings and rebuild." In the settings, I made sure that I was pointed at the correct template and re-built again, but still saw no change in the hatch. Finally, I deleted the entire map book and re-built it again from scratch, but the hatch pattern has still not been picked up.
Does anyone have any ideas as to why the changes to the template file are not being picked up?
Norm
BOXX Technologies APEXX 2 2402 Workstation
Intel Core i7-6700K @ 4.4 GHz
32 GB RAM / 500 GB SSD
NVIDIA Quadro M2000 Graphics
Windows 7 Pro 64 bit C3D 2017
