• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Map 3D Industry model, Oracle, coordinate system problem
    162 Views, 0 Replies
    06-29-2012 04:01 AM
    I have situation like this. We use industry models and Coordinate system MGI. On every model in Infrastructure Administrator Coordinate system has been set, even on every feature checked. In SQL developer I can see SRID is ok.
    Problem is when I generate graphic or add data from FDO provider (Topobase provider or Oracle) I can't see what is the coordinate system. I am thinking on the screen where you make connection and you see all the features which are available in data store. It says Coordinate system - Unknown. On the second machine I have all the same thing. Same database, same database(on server), same client, same db client, but Map 3D can see what coordinate system is.
    Problem is when I try to draw feature to unknown coordinate system, it says Coordinate system has not been assign globaly. Ok I asign it from Map, then I can draw, but drawn object moves on completly different coordinates. Simply said it doesn't show up where I drew it. Checked in DB, object has different coordinates then I drew them.
    I diagnozed the problem doesn't exist when coordinate systems match, but when Map reads unknown coordinate system which has been set to MGI, problem exists.
    Problem shows up in both Oracle 10g and 11g, both AutoCAD Map 2012 and 2013, both on Infrastructure Map Server 2012 and 2013, but only on some client(server for IMS) machines. So it must be due to Oracle client or to AutoCAD Map.
    Does anyone have similar problem and any solution?
    Tnx!
    Please use plain text.
